Done that still throws them out!!Yes red locktite them in place. They have a flat spot on them. Make sure grub screw is tightened on the flat spot.
Do you have a link to aWeb address? PleaseI replaced mine with the FLM hardened ones...lock tited em on real good...now the grub screw hits my lower steering link brace entire front end is shot. They haven't fallen apart yet!
new whatNow now, I've done these more times then I can count. Clean the ends with 2+2 or gum cutter let them dry. Get a good new grub screw. Grab the red loctite goop some on the grub screw. Crank that sucker in there good and tight. Let it sit till the next day. Your next post will be asking how to get the grub screw out. Use heat. Once you figure it out you wont have so many pin issues. I use a new grunt screw every time.
too late?Fixed it ?
My dbxl keeps throwing out the pins that connect the shaft to the diffs, there held in with grub screws
