Dynamite Kill Switch with DX5PRO
Edward3340
I am trying to install a kill switch on my Rampage XT. The kill switch is not lighting up and when i set the aux switch to button H it’s still not working. Truck will not start unless i unplug the kill switch. I have a SR315 receiver. Please help
Ok update, i plugged It in the steering port and light came on, when i plug It in the aux port i can’t get It to work. I volt tested the aux port and i get 6.5v. I feel like there is a setting in the remote i am not setting.
I have a 3 channel receiver and i put It on the only aux port got no light, then i put It in bind mode and after It finished still no light
Here is my step up with DX5R and Killer Bee.
Bind with frame rate @ 11ms
Channel Assign>Channel: AUX1> Input: -H-> Momentary: Inhibit
Full brake then bind.
If I remember correctly my kill switch didn't work when I bound the RX @ 5.5ms frame rate.
You may also have a bad switch as mentioned above.
Good luck and welcome to LSF
