Engine exhaust port larger than pipe connection
RcAlchemy
I have done a quick search and haven't been able to find the answerer I am looking for. Currently I have a stock Thor pipe from KM on my buggy and looking to change it out. My questions is...why is the Rovan (DDM copy) pipe flange connection a smaller bore than the exhaust port on my 30.5cc engine? Can you grind out the bore on the pipe to match the engine exhaust port? Hope I asked the question correctly. Thanks!
yes mate, as long as theres enough material ya can grind away to match the header to the exhaust port (y),
easiest way is to just nut and bolt an exhaust gasket to the header and grind to the size of that,
but why is it smaller and why not just match each other? is there some kind of percentage of exit exhaust into a pipe for horsepower?
May possibly crack since the metal is of lower quality also
i was thinking of that
Its just a low quality pipe as long as it looks the part that's all they care about. Any higher end pipe will most likely be port matched. My olimat and vrc pipes are the same size as the exhaust port
thanks for the reply
true
I had the same problem, best advice was to get a real pipe, but if you can just get a Dremel and port to a regular gasket, if pipe diameter does not allow to go big enough use the dermel and taper it (make a funnel shape). Can you post what pipe you have?
Port matching weather it be on the intake or exhaust side is always advantageous. Your engine is simply an air pump. Obstructions cause flow problems. I have the DDM Dom pipe and i had to do a small amount if port work on the lower edge of my flange. I also had to machine the face of my flange as it was warped from welding and leaked oil. I also port matched my carb velocity stack and the carb manifold . Its the small details that make positive gains. The key to sucess is work in small light steps with a grinder. If you get too aggresive with a grinder you quickly end up with a junk part.
There actually is, but I don't want to get into it, and it refers more to the port area size, and pipe size, the outlet flange should be a seamless transition from port to exhaust.
