Thanks mate , so if I can afford one you reckon a 50cc would be a good idea , currently running a wheelie ported 29cc (30.5)Yup they all just bolt in the same except for maybe some bigbore engines? Used really ain't worth it unless you can trust it hasn't been run hard or much for that matter. I don't see many deals on engines that I say to myself damn that's a deal.
I am planning on torquing up all essential parts but find info is aKm baja KRSC 002 mate
Km baja KRSC 002 mate ,one other thing do you know the inch lbs torque settings on the exhaust?
Thanks manYup they all just bolt in the same except for maybe some bigbore engines? Used really ain't worth it unless you can trust it hasn't been run hard or much for that matter. I don't see many deals on engines that I say to myself damn that's a deal.
Throttle finger destroys parts.A big bore will destroy a rovan.
Lol maybe no then,need to save for a hpi, cheers for the heads upThrottle finger destroys parts.
Thanks,it it worth getting a 50cc for speed?I don’t think you’ll find a used big bore. Check Detroit, he gets the odd one in. I have a 5t baja with a 50 in it. Get ready for forking out lots of $$$. It’s not cheap.
Doesn’t matter everything you will upgrade needs to be done anyway. My 5t with a 50 in it has only a small handful of hpi parts left.Lol maybe no then,need to save for a hpi, cheers for the heads up
It is for rips upThanks,it it worth getting a 50cc for speed?
Is the 50cc worth it speed wise?Doesn’t matter everything you will upgrade needs to be done anyway. My 5t with a 50 in it has only a small handful of hpi parts left.
What parts do you buy?Doesn’t matter everything you will upgrade needs to be done anyway. My 5t with a 50 in it has only a small handful of hpi parts left.
It is for rips up
And down the yard. Takes the fun bashing out of it. Putting a bb in a baja changes what you do with it.
Black bone gears in trans.Is the 50cc worth it speed wise?
Pricey???Black bone gears in trans.
Billet case and diff cup.
Innovative dog bones UHD
Um necessary plus a kraken extended arm kit. Going to need the extra width for stability. $800 usd. Ish.Pricey???
Wow ,is it worth the money?I've also got a 3s xsyr pro (not working,drive shaft keeps popping out on the front)and damn can it shift...Um necessary plus a kraken extended arm kit. Going to need the extra width for stability. $800 usd. Ish.
Yea fair one , there's a custom guy stateside that does some cool as fk stuff but well dear ...For speed a twin is best. Your looking at 5-6k if you can't find a good used roller w/ a wheelie bar. Then you need tires that can handle the power which is gonna cost some coin in itself.
I've seen them run and it's something to watch for sure but for 5-6k I can buy a real car or bike and actually race it lol.
