Exhaust joint chewing up gasket
ChrisBlue233
Hello all,
I was gifted a 1/5th Exceed Barca and I know it’s not the best one but it has been working well so far. I put loctite on everything before I even began to run it so nothing would come out. Anyways, I am having trouble with the exhaust joint. It has chewed through the exhaust gasket that is held together by springs. I ordered a 5 pack of gaskets that should be here in a couple of days. I was thinking of putting some rtv on a new gasket but it probably wouldn’t help maybe there is too much gap. How would I go about bending it I’m afraid if I bend it too much it’ll rub against the plastic shroud of the engine or I’ll ruin it? I have a mapp gas canister so it should get hot enough. Should I also get some exhaust strap and figure out a way to stabilize it because the metal hook with rubber on it doesn’t hold it as it slips out? Thank you so much.
I can't get a link but search ebay for 1/5 Baja header clamp.
Not sure if it will fit but I have a similar pipe with one on it.
I ended up bending it in a door jam to straighten the end that’s crooked. It’s better now but I had to order new springs because they are all stretched out.
