Exhaust temperature?
Jetjoe14
Ontario
Hello,
Yes yes I'm new here haha.
Just finished building my Kraken Vesla and am using the Zenoha G320 and Rovan tuned pipe.
Just wondering if anyone knows, what is a typical temperature to expect around the expansion chamber of a pipe?
Reason, i have a decent size crack going through mine (my fault not Rovans) and was going to use solder to fix it, but I'm concerned the pipe may get hot enough to melt the solder when driving.
The solder has a melting temperature of 430F/220c
Thank you for your advice :)
Hello,
Regular Solder will not hold up. Brazing rod will but requires a map torch, at a minimum, to get enough heat in the metal.
That looks to be aluminum and at the header on a mild steel pipe it will turn blue/purple so I say max maybe 530-550 degrees F.
If it's aluminum it will melt trying to braze it unfortunately. Ive tried it on an aluminum pipe I was trying to fit on a saw.
I think you need to fuse the base metal and some filler rod to properly fix that. That crack appears to be continuing off camera there. You need to weld that, brazing could plug it up but running a bead across it would be better.
I agree. Tig welding is the best option.
Ill take it to the welding shop on Monday and see if they can weld it along the seam and fix it up. it's apparently steel but can't be certain the entire pipe is steel. I'm sure a professional welder will be able to tell. thank you for your advise !!!
OK , my two cents.
Tig weld and it isn't the easiest stuff to weld being so thin. I welded a pipe for my DBXL and it was tricky.
1/16 tungsten , very low amps and the thinnest filler wire you can find, I used a piece of .030 or .032 mig wire.
That appears to be a seam that has split , you can see it continue in a perfectly straight line right off the right side of the picture.
