benckie
F1 Competition 08/ Zenoah 26ccm with
hydr. brake system
Item N°. 10005
F1 Competition 08/ Zenoah 26ccm with mech. Tuning brake
Item N°. 10006
Just like all other FG Competition models is the FG Formula 1 Competition the most successful model of the past years. The experiences we gained from numerous competitions have all influenced the version 08. An important innovation is the FG gearwheel drive which is extremely smooth-running and cares for more power reserves. Surely FG Modellsport has created a competitive model for the next years with this 08 version which will seamlessly follow up on the past successes.
Equipment of the FG Formula 1 Competition 08 kit:
CNC-cut 8mm alloy chassis with lateral carbon fiber inserts, 26ccm Zenoah engine, inlet silencer, Tuning pipe, viscous locking differential, FG gearwheel drive, ball drive, complete rear and front axle carrier unit with integrated engine quick-fixing device, double alloy wishbone fastenings, lower alloy delta wishbones at front and rear axle, front and rear alloy uprights, ball-bearing servo saver, steering stops, pushrods, 4 oil-pressure shock absorbers with alloy damper pistons, hydr. disk brake or mech. Tuning brakes at front and rear, stabilizer for front and rear axle, 10mm alloy balls, carbon fiber rear spoiler, polycarbonate bodyshell, polyamide front spoiler, receiver box, competition tires with tire inserts.
We deliver the models as a kit including mounting instruction. The body parts are made of clear polycarbonte for your own painting. FG stickers and writings are enclosed.
For the final assembly of the models you need further: radio control system (transmitter, receiver), 2 steering servos (each approx. 15 kg), each 1 throttle/brake servo (approx. 15 kg), batteries and charger
FG- FORMULA 1 COMPETITION filmed by BERGYOGI
