mickthrottlejunky
Anyone try the FLM extended arm kit? Was thinking about putting them on my DBXL
Did your kit come with the new 5 mm pins or the 4 mm
In the drive shafts
Though they were the same the front and the rear
The front will fit the rear
Yes but you can put the front in the rear
Wouldn't the dgi axle extensions have the same affect as these extended arms? Axle Extensions give the same track width, therefor the same handling characteristics No need for messing around with extended shafts, tie rods etc. $60 for extended axles vs $225 for this kit that needs special shafts when they wear out?! I just don't see the value in this. Huge bling factor but just unnecessary. I can go to almost any hobby shop for replacement driveshafts, control arms and tie rod links.
