friggin turnbuckles keep pulling out!! GRR!
Royal Male
Brighton
GGRRRR...is it SO common for the turnbuckles to keep pulling out of the rear lower wishbones? for the last 2 race meets its happened, really annoying. :mad:
Is the only way to solve it to go ally?
I might resort to aralditing them in :p
cheers lads
is it the rose joint end or wishbone side i know its a pain in the arse as mine still likes the odd rose joint but the way i see it is if i had all alloy rose joints and arm ect then it would cost much more to fix after a few crashes and rolls the rose joints are the only plastic left on mine for that reason something has to give id rather it be a £1 plastic r/j than a £35 wishbone
hi mate, they are pulling out of the wishbone end, the rose joints are sound, I have the red mcd ones.
so are you saying the only plastic you have is the rose joints or the wishbones? I have metal rose joints on the rear wishbones (chassis end).
yeah its the rose joints on mine thats the only plastic/stock parts theres only 2 on the front wishbones of mine as im using kdp lower arms and the 4 steering ones they have been on for over 3 years its the rear inner ones that give me hassle the rear outer ones right at the arse of the car ive not long changed to alloy as these aint a issue
Same here...almost full alloy Baja but still run plastic rose joints and plastic shock bottoms...got to keep the weak link in there somehow...
:w00t::w00t::w00t::w00t:
maybe turnbuckles are on there limit....and not in far enough?
on my topstox ive measured where/angle etc and used 8mm s/steel threaded bar so fully in and used 6mm bar and and rose joints from bottom wishbone to chassis for extra strength....cus topstox go thro some stick out there....lol
