Front hubs
Busa169
Dorset
Hi,
Can anyone tell me if either Lauterbacher super X or Hormann HT1 front hubs will fit an FG ?
Or do FG do a front hub to take Hydraulic brake calipers ?
I have modded some alloy FG font hubs to take some Laut hydro's, but they don't seem to be holding up too well.
Thanks
Daren
FG make the alloy front hubs you need for hydros, normally always the odd pair going cheap on Ebay. :)
Here's a set, pricey but you can find them for around £40 new on Ebay if you're prepared to wait.
Alloy Hubs
I have a set on my MT. Brakes mount in the rear so as not to hit the arm.
Thanks for your helps guys,
Ducky, the ones you have a link to don't work, thats the ones i've had to moddify.
BTB, your cable calipers mount to the side rear, my hydros mount central front.
If I use the standard plastic hubs they mount fine,just wanted a stronger hub, I have since found out that hobbypro do a direct copy of the plastic hub in alloy .I found this out after I had some hubs machined up by J&A Racing , never mind hope this helps someone else in the future.
Thanks
Daren
Those alloy hubs are the norm for a marder, I use the four bolt ones on my MT. What car do you have Darren?
