hi mate i have a smartech spider basically the same as the uno and they all leak fuel from the breather all of them ! its a common fault with the smartechs what you need to do is change it for a fg marder one and make sure you get the strap with it to mount it to your car as you will need it ! they are cheap on ebay and fit straight in and no more leaks !i have from the Gas pipe leak (not from the tune pipe)
why? see picture
they have a fuel line a fuel return and a breather and the smartechs always leak out the breather ! you need a marder tank !hi mate i have a smartech spider basically the same as the uno and they all leak fuel from the breather all of them ! its a common fault with the smartechs what you need to do is change it for a fg marder one and make sure you get the strap with it to mount it to your car as you will need it ! they are cheap on ebay and fit straight in and no more leaks !
thanks
why its Happen?
can you send me the link to ebay where you buy?
Don't know why it happens but all the smartechs leak out the breather il look on ebay for you
copy the link and just past it in the new message\topic-its workHi I can't link it to you because it will only let me email a link or share it with Facebook if you just search eBay and punch in
Fg marder fuel tank there is 4 or five for sale with the mounting strap for around £12.50 you will notice there is no breather hose !no leaks
Just fit it straight in mate !
Hi
thanks for the information
why you do not write this problem to smartech if any resolve from the factory?
this is the link?---http://www.ebay.com/itm/GENUINE-FG-...LTER-MARDER-BAJA-MONSTER-LORRY-/271055050938?pt=UK_ToysGames_RadioControlled_JN&hash=item3f1c23d8ba
