rcspeedmart
what difference on the engines does the gasket thickness makes I see they come in 005, .012, .020 and more, and is there a difference in the copper heavy duty steel which is better? Thanks in advance.
Thanks for the tip!!!!!!!!!!!!!!!rob64n said:put a .012 in it, although I have also used the .005, it makes a nice difference
I always thought when you have more compression you get increased torque and RPM?Deluge said:Depends on what you want. The higher the compression, the more bottom end you get. The lower the compression, the more top end you get.
