Boostedmk3
- Reaction score
- 24
So my current vertigo carrier aligns as such .. ive had a verigo clutch housing with a TR clutch carrier with similar results on my last 2.0 build. My question to you is how did you assemble the locker and what did you carry over to the locker as far as did you keep the thrust washer and oring? Did any bit of the assembly procces fight you and did you make sure to put the bearing with the zip tie on the spur gear side?..
also theres only so much movement that can be had with the clutch housing and carrier due to where the clutch bell needs to sit in order for it not to contact the clutch with it sitting too close to the end of the clutch towards the snout of the bell. Got any better pictures showing the locker spacing inside the tower?
View attachment 83013View attachment 83015
Try removing that gasket as that is a shim in a way, seeing how thick that gasket is that would put you mesh even with eachother. I put mine together the same way minus that gasket as there's no real need go keep a gasket in an area that doesn't need to retain fluid.. how about the carrier? I'd that pinion bottomed out on the clutch bell? Can you pull on that pinion, will it pull out toward the spur? I had that happen to me when the pinion screw started to back out and looked similar to that.
