+1, as always,need more power to push taller gears without sacrafising too much take off but ive never had a 4wd fg( sounds good tho) tried the mcd rr and ftx punisher.
if you have the stock g260 2 bolt zen and stock can,id leave the gearing. if you have a pipe then
just go up 1 size on the outside gears. so if its 18/46 go to 20/44, one step up like this gives me 7mph but with 2wd it still spins the wheels so no bogging once it hooks up further up the rpm,with im not so sure with 4wd .
the mcd i used was abit boring with stock set up, but as soon as it got a pipe it was some of the best rc fun ive had, i think if the fg4wd kit wasnt so expensive id try it but ive seen the kit in my lhs,you gotta change alot.
dwarthy is stock fg 4wd gearing 18/46 like marder or 16/48 like the mt? i know its a 14 lay which is tiny but needed.
i thought your bug had a stock pipe and engine by the way you go on!!! i think your just too modest sometimes mate. a headkit from ddm and a tuned fg pipe is well enough,especially to spin a 4 wheels mate.gotta catch up with you guys over the summer ,did you see how my ht2 looked after smashing into a 3 ton concrete block at 30mph lol,in hormann section.
back on topic, let us know what power upgrades and wheels you use,then we (or dwarthy lol) can help.
I hav a stock engine 26 and a dom pipe. i want it to go faster
22/42 your going to have to give it a push start mate just to get it moving mate
Looking at the gear calcs table......
4wd ratio is 18/46 14/48 and gives a top speed of 33mph
2wd ratio is 18/46 16/48 and gives a top speed of 38mph
quite a difference especially when the 4wd can use that power off the line.
Changing the main gear.......
4wd at 20/44 top speed = 38mph
2wd at 20/44 top speed = 44mph
4wd at 22/42top speed = 45mph
2wd at 22/42top speed = 51mph
The 14T layshaft gear pretty much puts the 4wd 1 gearing behind the 2wd so 22/42 will be fine. Could even go 24/38 at a push :w00t:
nice find dwarfy good info there i think mines a little bit quicker though due to running the larger hpi wheels which is probaly the same difference as going up a gear i think
the charts are good, but after a certain speed they aint as accurate due to tyre inflation and also if using a tuned engine or pipe withe improved rpms , will get more top speed.
