Giant Half-Scale Build
Thanks J!
Things are starting to get pretty crowded around here. Hard to tell from the pictures but that is the throttle / brake servo stuffed in the last bit of space.
DYV8x-Zo-5tpOFL0cIBoIJTcIl-_SV-KM_ERkzSIrn5U3c1it8tRIxaup4vHfzsKlqsRPRWJ9A7Fkbi8l4fgOQy1uTYJa-rAumXBBKgyyq_sLMNfREGFpMSKnGJWDlBliXZosSFedhw5hUrQMpTqL88VWkFGeu-Du2pSZEj8DMcNY157uEDL0gYgDr3YzWjL7vXq52J0Ym30Gz3yniMw6Opp4NT65TEsaFSIviTUqyONVvoXOOqUzIHtIjHJIzQD0nkr69LlnsK06mJbysHUab_DVTJ8Bdmv2nyWpH177xI8g_PLSfMpS2ABs61rOYGiZMTj09VJwZtNOCn4lwYE7S5scxKwZAk7UXjyS6qMFHwwSj8h-GtOo5zVUb64NXAqRFTsIyeea33xu00EkfaijHZWqO5mx2mldqi8v--xz_fsH7mW3to61Eyyv2kmftRibbEjtDVU-sLdNv_3JLoyLhqp4XgreYBKzWtuuF90JTXevk2Pfl1plvGdnV05Dd83BLjmjhxAmWP1y-FvVfsJGKYaHyu8vB_dAR-y9XuqtLauFVYmolRCXInMralTQ3GEcZ_LC4YsJAUUe7frneJujYWksaWFWlcTS25h3m9SFSKXOh-esJwjtuRdR3KOaS2cwO6sINTSmebTT9fqCYq_AQWsfRGLq1w3IgYvnK520qyK5W9SWOxKLycpEQ1mXCaZiuuVgRy-AVjEIdAyZjcKmRKMPEd_g8a0yz7vs6RlRYao3Mo=w1183-h888-no
fzOX2pgw5HSBcTlRSRHce6cNjhAPORjWyzSyVi1qqVXBBu0vJskbSJweWxk_KLGevszdRD2kRcaR1lscByaHWjrIsBNaauXWbfXlW-izIzvpJQc9QjFjPPD-xgbRDgQE7cUPlXHiHK7UQQp7yWdWnMCrtXSjV7ZeNSuILXWSk5EyfxClUAhW2NePYjMVbCkglnT6ml0le-Wbw9veWdlMjOhcLNAV9T074aLv-lYmGsjvNnZ0Fl1C5rxsufcsKYDqnBdStP82uGexaHT9DqqE0I0g8XezRPVWpK-pIrLXr_6ns2VFDxav_1dO54pW8jtLk7Is2HJbKNa7JxA7BdYmLAtSnf2XfiX9K6VTktYUyeJSpbucxEEoCC86gPrDev9uID0pTSfsUCdzaGOl9UQ21YtzMjiaSYDc4pTFnd-iMOVPD_GfSiYOTp0Y0ba01APhck82PYFSZ5QjLs3z3aucFwSev3CUekVj_3IpaZ12Fzx4Oohp3w3ayDDQ9_E6FM2ES40fHVgC7fpRkEYNfXXg6f3PfNcp-qlE4MdnuHDj6h3cgU6dobTADKsciMTD8Urnz9k6XNs28v0x7sVxQ6igdW775JTTx69IrTIjhkn9JoQqOOYub6Xq_wERLqIv3pP1HXnS8ilbzCE-TNxXnMwOzNAxL3EWiKs3bscPPwWayjpvTa-5XGFb-4FzCKwyJ7i1b5JgKLLabnyUJPMkmyK8lULhlj4kE0y2MX-Fs6oUg2x1UY4=w665-h887-no
1oMNivqRoLgmVrNEYe6VZ_3hz3iPa-bLvE_PmLkxgVsiaTz8hKoXypyg2Pc_wunqE9nB-r07_n9k2nXaU7A9zDiTdmExafWouvJBtS3540tqYkAnmPEz16xPf6zqr5_XPKGdV76hbq3fT-duq1Kj066l3SFZe2dAqZeuo3FqfiqFINorVJ_VPF7SktcB5CrA1HcFrmgphpCNxRa9Ey4SNchIpVFF0eNCPc2ssoTEbK514eSmy849lXc032jGc6FUvgIDUXdcCEVDnxyyXQnhiYQG72Qv6HT3ujaswJypEqsIPhvNEf_1RciQzQAR0Z5-OEWMwAJLhHLjJXllABW7lsB9jWnLc6yMd3vLCxeGdTb3fU4YMZ_0evUPrQq6V9oIQVruZn49N22X9SvbSGJCLliz11xe8wrCwqmITCqEKqS7g3H2vWont0xncS8Aoa9yEySdTdeRGOXi21kitcVJvk2gbSmkkPIrK1GpZPUzJO3fEU8NczzvgEYauJ7XPT52YwWAHHMuuvC9b4rBYzfCGW8kLZb3gVSiyqrgrS4hdVYfVY0zm2easdYxFRpfcuUvPi2Fk2LkjHEOzG2gCtFQYlTsu82KQ5jctUy7i_2uOgfnb1kMLW4Yz59lA39kn_AZFJnccf7Wk7dJJx57DoRO5Yii0NqoNUJSXCHcIo_X7wm73R8PXPZrWqE7bB91TstxQC-MhdCLjnF6yHxO7vzbtBGlwmbQ7jxbHWF_DfrOE9rl6M4=w1183-h888-no
Ghr7pARGj1ZHnc4Ej3T2Kqz865vM7N4ON7ajEPWg02YUTNjoiPvrG5ziAtfwonX7Gag-VdrOipc-n9pZSTI6QXcSuyUOzbrssn14OgiADDbVIMeKZkMUeKXjN633PVy2RKYl-plUIw-YaI8Hnm1xO8R0bZUAdxVaKFYPvw9BDeYsaa_qikw4pKfzwg3WOz09cP1uKYrXJpXugJTjo_0TS7fbVmg_l77PNROzJv02hEqA4FWxpn4zCN76Tbj26KZ3OYuTN0Cu8s_IWv9ybwve6LsH7ZRSEOOWPO0nH2BnpdAqzaMVqsmHMnYaOVRc_daXTzkE1J5CSW_cKumWxLdcijtV0QbZ604L_b-toQMX2vn6vKJuUHKG8DHhjT4ziyR13aXtwHygNx97mOg4R9SmQ5RTp0YoMgNvj_5qXJ3Dllc5vyXgx8VPkU2rpM12-PIKhCzwMHF77tiJVKYg_CYTabiYMBObr_yl-sXSSGldrxcDe70c5600EUdlHx76joeqK02D_mJK0eeeucgeo4Ji5NO4yOcPmjXEelnj7gOm1AWw9JtBNRTJuFcrQDdQdfBh9NNqSVYZZzeWuNbmqBKaMEPw6V6rd8zKi5DV7J_Ee8nO4x_ehDvZChtGLZ1B_3SMYPO0no2a3YBqIuMxL9kiOWvDGQZOwT9KduOVz7VMinViRrmPmz6GDv38mCpbLqrpC5-xCB_XLBnBO1qwGy71Q0ity0ae-EH4uzonweNHW6yf-II=w1183-h888-no
5NrQjK3bDT1edjVW7Ym_QdQFcbfWVC4mCIGpzQBW2bBXuzwW_VDjoFyK-mNZkPlnBr1nXAxTW3zB3iqqgmlvBI7IaYo5NmdU2vOGPjroDeTmAUwcap6qd00lbWcwofsHaaIDj2ZTpRYyK8h7AYJ2nla3klQwzlTTR_cNtLWPXt_Kjr0ASSJ_VavFwAbVCIKm6S7b8n1ygCEUXtzhHqe-dNiWtxI_pp4fMsOBdse6Xg65RTLk8op6v5GUUUUgssVQGCjHnAZzTx4l1xy7Fz3ARnTolIzRxMPK56n3UXAA9q7Ut_YjwwmEl1iukn_c8-XSf5SVHIjlU4L5Zq8RwqxpGKCq34Uz5g8zqIxBmOUb2cJ7mznOvhzPvIzvB-2L_R4B-BhM7aHJvXVzZALVYCzAb0mGlmIJ5acMCS-A54O7lMLVhcPq527Xt1uTYNgeZup7fcLYpb_BQe7S5xUWLycFtXWSYXstNHCkQrpAAJwwO5fQYLh-xMXYRrrWO1FCAEiQ5XunIYRXP6SuNvX531-x3V7L8bwnpwFutxqc-6tjrP7vsBDH7Jp8wyQYlhG0PAMIPsWWTD8Zrf2D-AEiYcWM5Pn6MeHncLTJyJAlJsF9wS4I8IToA2ZRBzT8btVDP-0QDHSqHAQmbwCWGM6oC_NGNCKPlyCIypisl5c6ODv9-AsBiQI-g4CB1Cw263Nv0HNky7-0k5w-GXN6XN3BcWF4v5yvaDDInWoF-VYjpZc6tkYtIyY=w1183-h888-no
Thanks Sean. So close but still a lot to do.
I picked up a radiopost from the LHS and while it was in a drawer I busted off the throttle trigger. I have glued it back together and it should work but not too happy with myself...
Here is a bench test with an old Traxxas T/X;
I ported the brake caliper and lever assembly to take o-ring SAE fittings in order to hard-plumb the hydraulics instead of trying to shorten the original brake line.
Thanks a lot guys, much appreciated.
When the steering gets bumped past the programmed end points and over centre on the linkage it locks up.
I need to add adjustable hard stops for the end-points.
This is the first programable radio I have had, a lot to learn. Being able to adjust the servo return to centre speeds etc are really coming in handy.
