Hi there,
I just got a Dunerunner and it started great on the first time
I run it in for about a tank then stopped it.
Another week or so goes by; then I try to start it but there is no spark whatsoever
I kept on trying to start it and the pull start was very hard to pull; and I ended up breaking the plastic turning bit inside
. I ended up buying a new metal pull starter.
Anyhow, I went through all the posts in here and tried the following with no success:
1) I have check the Kill Switch – it is not stuck in anyway.
2) I double checked both the red and black leads that are attached to the kill button and the magneto.
3) I have also vented the tank.
4) I also did the business card trick with the magento to ensure there is good spacing between it and the flywheel.
So I thought its best to post a thread on here to see what you experts think...as I am no expert and just want this thing to work
Thanks a lot guys in advance
Jackpicc
Jackpicc
