rampage idiot
If I remember correctly an ohm meter should read close to 25 ohms across the terminals on the coil with both wires disconnected, also make sure you have 6 volts to the coil, the problem is I have seen coils have the correct resistance and still be bad, like rcdad said a bad coil is rare but it does happen
