Just took a few shots of my Rally with the gravel pack on and have a few questions to ask fello MCD owners.
Firstly--Is there any way of changing the axles to ones that will take the standard FG squares?
Second--When on full compression there is still about 1" to 1"1/2 still left on the ground clearance.Should the chassis touch the floor? If not is this dangerous to the shocks as they will be taking the full force of the bump/jumps under compression !
Clive,if you read this can you give me detailed shots of your Scoobys set-up.
Thanks fellas.
J.
Thanks fellas.
J.
