GTB and FID are they the same ??
smurfer69
Weston super mare
Does anybody know if GTB and FID racing are the same
and does anybody know where to get spare parts from
cos I have tried the web, emailing, both sites are out of date
well FID is 2011 is last year that shows on there website,
there products are so well engineered your can't modify them
certainly not easily, but the simple things like screws washers,
springs should be readily available.
im ranting , both companies are so bad
any help would be very much appreciated :mad::mad::mad::mad:
Angry Smurf
unfortunately the part I need isn't there and its all for the 4
brake option and the master cylinder in completely different, its weird I can
fill the brakes will oil no air bubbles established how to do that,
now im thinking ive got a servo problem not because its broken
but because its not powerful enough at just under 10kg to do hydro brakes,
even doing endpoints and other adjustments I can't get piston rod,
to go in far enough into the master cylinder to lock the brakes up,
if I push in manually by hand I can lock up rotors , no way of moving,
thats what I want the servo to do ,but think even with another it can't turn enough
to push in enough,
wow almost confused myself then o_Oo_Oo_O
