tizdaz
Hi guys
ok went with my MB after a major overhaul of fitting new bits etc..
I Also fitted a new head gasket, after a run i re-tightened the head bolts as they came loose a bit.
I didnt put any thread lock on the bolts! (yup i know not very clever!)
anyway not sure what to do now.. its a 2 bolt so would it be safe to take 1 bolt out, thread lock it & slap a spring washer on then put it back in & tighten it up, then do the same for other bolt.. OR should i take both bolts out @ same time & do them together & tighten them evenly again.. only prob doing this will i lose the seal of my gasket if i take the both bolts out @ same time
its a catch 22, cuz i know when we tighten head bolts we meant to do tighten each bolt a bit at a time so when it tightens its even. But to do this i would have to take out both bolts & im thinking then that i will lose my seal on head gasket
? im using a normal gasket with gasket sealant.
I don't wanna be fitting another head gasket as ive only just fitted this one & its fine with no leaks but i know my head bolts will come loose again! so i defo need to thread lock the bolts & throw on some spring washers
suggestions!
suggestions!
