Yeah... Large scales are pretty fast, but they seem a whole LOT faster when you are running after it!
Isn't that always the way, your stock 26cc turns into a full blown reed motor when it's out of control!!!
the thing is tho it has a fail safe stuck to the top off the battery box thats why i cant understand why it did that...clearly the fail safe is not working...good job i got duracell 2650s in my controller ...
i disagree. and im sure im not the only one..... no need to explainmmm nobody to disagree with me,strange lol..well i am going to stick to my good old air tronix anyway,happy out with it.
batteries and transmitters arent finicky. the problem is mostly between the trigger and the finger. and a pico doesn't just turn your motor off whenever it wants to.well i would agree with it if the engine could be switched off manually from the transmittor (or can it,have i been sleeping lol) otherwise not a hope would i put up with something switching off engine at any given moment and no need to explain this either,we all no how finneky battries are and transmittors..
you obviously don't know much about this subject. the pico doesn't turn off the mill when you go out of range. thats what a faislafe is for. and also setiing your failsafe to full brake is not so smart. by the time you get to it your servo may be fried. and going to pic up your rig is safer then salvaging the peices once it hit a small child. and so you know ive been rcing since 1990. and i have 3 pico's. have you seen my runnaway vid? that could have been really bad and a failsafe does nothing in that aplication..of course they are,battries don't always charge correct,im in large scale long enough to know that,what happens when your car goes out of range? your pico kills engine,well thats no good to me when i need to run long range like football field or something.
have you got a pico like?
otherwise how can you know
i second that, but if you go to the dunes you have a wide site range so running that far is easy. andfunny you mention that. i got stuck yesterday at th gulf coarse in the snow. had to tretch down to retriev my beast in a vally and couldnt get out. my rig made it out fine. was sitting at the top of the hill wauting for me. it ran out of gas before i made it to the top.. was kinda funny once i got to the out...There is another option... Don't run your truck a 1/4 mile away!!! What would you do if it were that far and it flipped over?
