alfred e numan
- Reaction score
- 0
DO THIS. Remove your cars reciever. Gently. Look at where the antenna wire enters the rx case. Its a loose fit. This puts all of the stress from the antenna wire directly on the two solder connections. They WILL eventually fail -- the copper circut trace will break off the printed circut board. Most likley this will be the outer wire on the antenna- the shield- counter poise wire. If this happens, your radio will still bind up on the bench cause the tx and rx are so close. Its range will be limited however- if the antennas center wire connection on the p-c board breaks- you will be shi$ outta luck- The broken connections can move around in the rx and cause a total loss of control- no kill switch- no steering- no throttle. This happened to me last weekend. Enough about that. The solution is to remove the two rx case screws - pry apart the case on the antenns side, apply shoe goo on the 2 U shaped indentions where the antenna wire sets- then reassemble and let the glue dry. This puts all the stress on the glue area. instead of the fragle solder joints on the p-c board. DO THIS before you have a big time run away the way i did. Should have trained the damm dog to fetch the car before it hit a concrete retaining block @ WOT.
