for the past several years it's been a common issue with walbro carbs. We've witnessed many complaints with the same symptoms. Low, no power on top end. Runs fine at idle to mid rpm. Stumbles, stalls, return to lower rpm/idle it's OK again. Certainly not a cure all, but easy enough to check and set and won't hurt the performance of the engine. We've been down this rabbit hole quite often, to the point where guys have thrown new carbs on to have the same issues.Rcwrecker.
Sean shared good information however, in all my years I have never had to tweak my POP off pressure. I have replaced diaphragms and springs during carburetor rebuild but that is all.
FYI, the POP off pressure is the pressure required to move the carburetor needle out of the seat so fuel can flow. Based on what you shared this does not sound like the specific issue that you are having as you are able to meter the fuel via the low and high speed needles.
I’d encourage you to focus on the simple and somewhat obvious items at this point. It’s a new rig and for you to blindly open the carburetor and make tweaks I think is premature.
Here is a description of the POP off operation as shared by another for your reference.
The pop-off pressure is the pressure at which the needle valve will open thus letting the fuel to enter the metering chamber. The value of this pressure is a function of the engine, power output and other factors and it will directly affect the air-fuel mixture that the carburetor will deliver to the engine. It is true that the mixture adjustments are done by the HI and LO screws but if the pop-off pressure is too high, it can lead to fuel starvation especially at high RPM. Such a situation will cause engine overheating and possibly lead to a seizure.If the pop-off pressure is too low, the carburetor will have a flooding tendency especially at low and mid RPM. It will also cause difficulties in restarting a warm engine.
Great write up .. thank you
