twissted
so I used arrows to show some of the mods that have been done. stuff you can't see well I will show pics of later.
The motor is the stock 26cc I drilled and dremel the clutch housing so that it cooled better I did this by drilling between the fins and dremeled from the back side.
The flywheel is drilled out and then rebalanced so that the motor runs smoother and cooler. It being lighter in weight lets the motor rev faster.
The cooling vents for the motor was covered from the inside with copper screen so that rocks wouldn't break the fins off the flywheel.
The carb. was left alone but the end bell was changed so that I could use the TGN 3 stage one piece filter.
Moving to the servos I went with the Savox HV high torque unit up front and moved the stock front servo to the rear. I added a lipo 7.4 3200 battery from HK Nano-tec. With the add power I added some bracing so that the servo brace wouldn't move. This added more braking power as well.
Working on making smooth steering was done with adding a DDM RACING ALUMINUM FRONT TOP CHASSIS BRACE. Also I added a Hot Racing steering link.
