Hi, wanted to pick your brains... i have the troublesome brake layshaft issues and i think i'm finally getting it sorted.. on the brake layshaft (d Gear) when its all in place the whole layshaft from d gear through to the diff gear moves as one piece about 2-4mm (roughly) either way forward and back so the d gear either overlaps each edge of the c gear by the same mm.. Now is this ok or should it be tight and inline with the c gear at all times?? (hope i've explained it ok if not will post a couple of pics to show what i mean)
