Want to re do my diff on my hpi? the stock oil is 1000wt silicone? what are you guys running? I was thinking to go 2000 or 3000
Well ill be running 500k and later trying out 1mill. Probably doesn't help since I'm running a 71cc lmaoWant to rebuold my diff on my hpi? the stock oil is 1000wt silicone? what are you guys running? I was thinking to go 2000 or 3000
Mmm may as well just use a diff lock if you plan on using 1mill.?Well ill be running 500k and later trying out 1mill. Probably doesn't help since I'm running a 71cc lmao
No, with 1mill there's still a bit of "give", with a locker, there's zero, so the 1mil with probobly handle better but I think I want to try both now ?Mmm may as well just use a diff lock if you plan on using 1mill.?![]()
That is kinda Tru ?????You Only need a diff If you are going round corners...... and you my friend will only be (trying to! ) going straight![]()
Thanx mark ill try good middle ground 4000/5000I run 7k in my basher baja doug
