ChuenouXiao
Why are these breaking apart? What causes this? Are there any better quality head that I can use on my Zenoah OBR with no problem where I can just install it and works fine? Are the head material too cheap?
Where should I get a upgraded working head for my obr?Deluge said:Looks like you might be over tightening the spark plug.
What if I want to replace it?Deluge said:Honestly, you don't need one. That's not a major issue. Just don't over tighten the spark plug and you'll be fine. Hand tight plus a 1/4 turn is all it needs. Put some anti-seize on the threads, as well.
Let me contact OBR... see what I they can do to help me....Deluge said:The only place you can get a head with the same porting, would be OBR. And it'll still be a Zenoah head. If you have crap falling into the cylinder, pull the cylinder off and clean it up.
I un-mounted the engine head.. and cleaned the particleDeluge said:The only place you can get a head with the same porting, would be OBR. And it'll still be a Zenoah head. If you have crap falling into the cylinder, pull the cylinder off and clean it up.
Deluge... when I try to tightening the plug into it... it just never lock up. This is when I know all the treads are gone...Deluge said:Nice. Hopefully OBR can help you out. Weird how the threads just fell off.
Will upload a pic here soon....Deluge said:I've honestly never seen that happen. Never even heard of that happening. Just a freak occurrence, I guess.
Here it is.... it looks fine to meDeluge said:How does the cylinder look?
Sean asked me if I want the whole kit, piston and all the other stuff.... its the weekend so he hadn't respond yet. I told him I just need the head for now. Deluge.... what do I lube my head and piston with when I put my piston into my head? Just 2 stroke oil?Deluge said:Looks good to me. No obvious signs of damage. Have you heard from OBR, yet?
