I think I need a new head for my Zenoah OBR Pro Stock
Deluge said:
Yep, just two stroke oil. What does the piston look like?
Here's two shots of my piston..... Please give me your thoughts... If I didn't take a shot from a certain position, that's because that part of the piston has nothing special... no scratch or nothing significant. The scratch on the piston is on the right side of the engine. Small scratches are ok (the scratches are very small... and not deep at all...)? Please give me your thoughts.... the rings seems fine... don't know if I should replace it.... probably is a good idea.... Base on this video here from this gentlemen... I've interpret that my engine runs clean.... there is no blow by but the gouge in the right side of the head causes the scratch i believe (remember the gouge from my previous post?). Do you guys agree with me?
[ame]
[/ame]
The C clip that holds the wrist pin in place is gone. Did you remove it? If you didn't, I'd tear down the case and look for it. As far as the ring, I'd put a new one on. The piston itself isn't horrible. The deposits on top of the piston are normal.
C clip? I didn't remove anything Deluge..... Got a pic? did you want to give me a time frame of team eddy engine rebuild?
Oh are you talking about the clip that holds the piston onto the shaft? Don't know the name. I think I C clip on the other side... I believe you only need it on one side only right? Let me take a pic....
ChuenouXiao said:
I don't have all the tool to take the engine apart.... :( Maybe I should send it back to OBR to get it fix? I don't have the flywheel tool too to crack the casing... :(
You can remove it the same way you remove the clutch plate. Just get two 6mm screws that are about 2 inches long, thread them in and pop it off.
Deluge said:
Or, you could get order a flywheel puller. DDM has the HPI tool on special. You're going to have to order the C clips, anyway.HPI RC/CY Flywheel Puller
Zenoah/CY Piston Pin Snap Ring (Circlip) Set
For this video below
[ame]
[/ame]I notice he use that tool to take his flywheel off, I can do the same thing but with two long bolt that will fit right? Or I can buy the flywheel puller you listed Deluge? Probably order the flywheel removal and get it over with... :( Got to save for it... :( Its going to cost me around $106 to replace my cylinder head and that's not considering this tool and the c clip. Also not considering gaskets... might be a while until my cars gets back up and running.....
He's using the Zenoah tool. I have that, but it's around $40. You can use two screws, but I'd get the HPI puller. This won't be the last time you'll need to take the flywheel off, so you may as well get the right tool.
You are correct and you do make sense :D So the HPI puller will work with my clutch carrier and my flywheel removal? Or is this one specifically for the flywheel?
