I think I need a new head for my Zenoah OBR Pro Stock
Deluge said:
Check these out...DDM Allen (Hex) Hardened Steel Drivers - Set of 5 (2,2.5,3,4,5mm)
To use them on a torque wrench, just get a 1/4" socket with the correct drive size and you're good to go.
Sorry Deluge, I'm so noob about this but I bought this
http://www.oreillyauto.com/site/c/detail/PFM0/W3001C.oap?ck=Search_torque_-1_2588&keyword=torque
With your harden steel driver above and this torque wrench... what socket do I need to integrate the hex to my torque wrench?
Yes, correct. The wrench you bought is a 1/2 inch drive. That's the square that the sockets snap onto. You will most likely will need a reducer. It might be hard to find a 1/2 inch drive 1/4 inch socket.
Reducer? Basically a conversion from 1/2 inch drive to 1/4 inch socket drive right? Then from there, I can mount my socket into the other end of my 1/4 conversion socket and use my allen hex bit from there?
Can you return it? A 3/8" drive torque wrench would be better. Then all you'd need is a 1/4" socket with a 3/8" drive.
This would be ideal...
http://www.oreillyauto.com/site/c/detail/KDT0/2956/N0730.oap?ck=Search_torque+wrench_N0730_-1_-1&keyword=torque+wrench&pt=N0730&ppt=C0216
Deluge said:
Can you return it? A 3/8" drive torque wrench would be better. Then all you'd need is a 1/4" socket with a 3/8" drive.This would be ideal...
Yikes.... I put in the zip code 95831 and it gave me the price of $85.99 for the one you listed Deluge???
I bought this before I bought the old fashion torque... I returned it because I don't know how to measure or read it...
http://www.oreillyauto.com/site/c/detail/PFM0/M202P/N0730.oap?ck=Search_N0730_-1_2588&pt=N0730&ppt=C0216
Sticking to the old fashion style :D
Deluge, maybe keeping the 1/2 is a good idea because I can use it for other automotive stuff? :D Never mind....... I realize that the one you listed is the best one available with that beam style with 3/4 drive for inch lb.... :( Prob have to get it :( The other newer style I don't know how to adjust and read the measurement....
You could convert inch-lbs to ft-lbs, but it's easier to just get an inch-lbs torque wrench. Looks like you got a good one.
a foot lb torque wrench could be converted but it would not be accurate enough to use on those little bolts . I have seen thread damage like you had in the plug hole, most likely the plug came loose at one point .when this happens the plug hammers and fractures the threads when the engine is running . you could have a thread insert installed to save the cylinder .you would not want to purchase the insert kit your self because they are very expensive and you most likely would never use it again.but if you contact a machine shop they could do it for you for $15 or so and it will be better and stronger than new with the steel insert.Roger
Good idea on the insert. Going to re-build my engine with a new piston and cylinder head along with the piston washers. If the thread shreds again... I'll probably do a steel insert like you said :D One thing I'm worry about is the thread insert might be slightly too high or to low when its installed, that's all :D
Deluge... since my C clip somehow flew out and probably went inside the crank case, do you think my crank case is damage in any way? I wouldn't think so but I'm going to open it up to clean the debris and check for damage. What should I look for while looking at the crank case.... I assume the bearings inside the crank case is the most important....
