ChuenouXiao
- Thread starter
- #141
Yes.... I saw that alreadyIldy666 said:Chue on the forth photo looks like the teflon basket is deformed and pushing out.check it out
Maybe I shouldn't even consider re-adjusting and installing? Too tight? Is it re-useable if I re-align? Do you experience this too?RCDAD said:They go either way, so I don't think flipping it will be any different. I looks like it is squished which pushes all edges outward. You can try taking it apart an realigning it.
Even though I didn't want to get my hands dirty after washing it already I went back and flipped the gasket. Its a lot better now. Just a very small portion is buldging in from the left side. So small it won't matter I guess.RCDAD said:They go either way, so I don't think flipping it will be any different. I looks like it is squished which pushes all edges outward. You can try taking it apart an realigning it.
Did you do a test fit with the gaskets to make sure you don't need to cut the bolts?ChuenouXiao said:Shots of my complete engine rebuild and the most important... my Billet intake and teflon gasket. It seems very sturdy to me when I torque to 30in lb as recommended by torque spec. So far base on my limited knowledge on my Billet intake, it seems like there shouldn't be any air leak although I've read about people experiencing that.... I don't think I would need to cut centimeter of the intake bolts and filter bolts so far.... please let me know what you guys think.
Deluge I did a test but my way of testing. I compared the upgrade intake to my stock intake, separate each bolts and put them on each intake. I notice the aluminum intake is slightly smaller.... about 2 cm or less smaller. But the Teflon gasket makes up for that loss of size and according to my judgment.... both bolts on carb and upgrade intake has enough room to safely secure. The reason for this is because when I insert one of the bolt on the fly wheel side of the engine of the intake hole, it shows me that I have enough space to tightening my boltDeluge said:Did you do a test fit with the gaskets to make sure you don't need to cut the bolts?When I tighten my intakes, I snug up the bolts and give it a half turn after that. Same with the carb bolts. If you over tighten them, the Teflon gaskets will bulge out.
Looks like the zip tie sliced it. Highly unlikely that it would cause a no start condition. Contact KillerRC and see what he can do for you.ChuenouXiao said:I think this is what also is contributing to my engine not starting before I rebuild my engine. Besides me installing my intake gasket improperly from my intake bolts coming loose and my spark plug threads being destroyed. It looks like I will need a new wire for my killer bee kill switch... I don't want to replace the whole thing... I hope killer RC sells it. It looks like a ground wire?
Ok, as long as you tested it. Should be fine.ChuenouXiao said:Deluge I did a test but my way of testing. I compared the upgrade intake to my stock intake, separate each bolts and put them on each intake. I notice the aluminum intake is slightly smaller.... about 2 cm or less smaller. But the Teflon gasket makes up for that loss of size and according to my judgment.... both bolts on carb and upgrade intake has enough room to safely secure. I think... its not me over tightening it... I think it's the way they cut the gasket?
Teflon gaskets are re-useable.ChuenouXiao said:Maybe I shouldn't even consider re-adjusting and installing? Too tight? Is it re-useable if I re-align? Do you experience this too?
Thanks budDeluge said:Teflon gaskets are re-useable.
Appreciate you pointing it outIldy666 said:Chue the forth pic. But if u say its good then it just might be the way the picture looks...carry on then....lol....
Deluge your thoughts on retreading the cylinder head if the threads do come off again?Deluge said:Let us know how it goes.
