How to set the ignition coil bak again, it took it off to put a new stop switch but aft I put it all back together the starter cord would not pull, it seems to be stuck. I applied too much force n it broke the starter cord pls help.
It needs a .3mm gap
this is the first reply with the correct gap size....:cup-1:
K....
Who on here is going to take a set of feeler gauges to their baja Keithy wiethy?
J.
K....
Obviously only Keithy Weithy and Kent
J.
Are feeler gauges pliable enough at 0.3mm or do they make curved ones?
(Serious question!!)
