Ignition coil
rajsbaja
How to set the ignition coil bak again, it took it off to put a new stop switch but aft I put it all back together the starter cord would not pull, it seems to be stuck. I applied too much force n it broke the starter cord pls help.
losen the ignition coil fold a business card in half put between ign coil and fly wheel press down ign coil and tighten, pull out the card should be right to go .....
Troy
Who on here is going to take a set of feeler gauges to their baja Keithy wiethy?
J.:rolleyes:
well if i had some feeler guages i would just to make sure the coil was installed correctly at the factory, i personally have seen coil spacing incorrect on all types of small engines straight from the factory so it is a good idea to check but in a pinch the card trick works
I bought the Zen tool because I am a tool freak and keep it in my RC tool box. I even keep a torque wrench in it for the motor fasteners and I torque every thing on the motor even the spark plug after putting anti size on the threads.
