Is The OuterWears Pull Starter Cover A Must Have?
It depends where you run. If you run in the grass, it helps. Grass tends to get sucked in around the flywheel.
Keeps the grass out and large dirt /dust off the air filter.
I run in grass now and then, I used widow screen and velcro over 80% of the car too...
Re: Is The OuterWears Pull Starter Cover A Must Have?
I would recommend in grass 100% as my my mt kept dying on me from grass getting shoved up on the coil causing no spark. Another thing I got was the slammer damn crank cover just like the outerwears but its cheaper so I got that and now my engine keeps on keepin on
that's great to hear then as i'll be riding on the grass like 95% of the time. so i guess i might have to get a couple then.
andy, i saw an outerwears shroud for the 5b & i thot of making a shround for the rampage chassis. i didn't think of using window screen tho. if we could get like a roll of the outterwears fabric or something like it we could make our own. this'd help stop not just grass & sand but moisture too. hmmm, if only...
slammer damn crank cover? wha??? i haven't seen anything like that. care to share a link? i'm a do some searching for it tho
That a great mod. You can also just use some wire mesh and shoe goo. Local stores will have what you need.
andy, that is badassingenious. it looks good too. kudos to you man. thanks for the link. i bookmarked it so i can go back to it for reference if i do the andy mod. :)
andy, this is what i meant about theshroud: http://www.davesmotors.com/s.nl/it.A/id.6206/.f
but you already got it covered, literally haha. ;)
thanks for the link rampagemt! i bookkmarked that too! this is why i do research before i buy stuff. good stuff here guys. very helpful to someone like me that is going to take the plunge.
Well now after using them & seeing the crap they kept out I'm glad I got these. They stopped a lot of small stuff. Cleaning them was just like removing the lint of the trap in a dryer. Def glad I got these. Now, if only I could jeep the rest of my ride clean lol. Sure would be nice to have a shroud like the hpi & losi's.
