Johnston.jer
Just got my baja and I am charging the battery pack. Are they normally charged when new delivered? I don't want to wreck it?
Thanks
Thanks
holds charge for 45 minutes, then I have to charge again for 6 hours?
Yes get yourself a better charger and rechargeable for the radio as well. I use this charger http://www.nitrorcx.com/75p-t6-multi-charger.html so you can charge everything at once in much less time. Also if you buy rechargeable batteries for your radio this charger also comes with a plug to plug into the radio and charge the batteries without having to take the batteries out of the radio. Also one other tip buying this battery https://www.redcatracingshop.com/ProductDetails.asp?ProductCode=1506 will make your servos faster!!!! I know that a 5000mah battery is just supposed to give you longer run time not more power but it is something about the venom batteries they discharge different I think but I have tried it against 3 other 5000mah batteries and these diffidently make your servos react and move faster.
pic of the charger i use
http://www.horizonhobby.com/products/prophet-plus-ac-dc-peak-charger-DYN4036
link to a site to read more details on it
I can't find that charger in stock anywhere !
What about this one. Thunder AC6
