- Thread starter
- #61
My coil tester shows the spark jumping a big gap. I cleaned up the carb last night and fired it up earlier. I drove it about 5 minutes before it did its typical thing. It starts sounding strange and bogs out when I give it throttle.
Removing the filter allowed it to start again but adding throttle bogs it down. The spark still jumps a good 3/8” gap.
Lever height is set according to the gauge that came with the spiral diaphragm kit. Pop off pressure is somewhere in the 22-25 psi range, hard to tell on the gauge on my compressor.
I knew it was rich while running because it sounded lethargic and responded to turning the low needle in. The plug looks fouled after that little run. I have left the needles as is to pick up where I left off.
What is the main check?Needle tip issue is possible, metering lever height would definatly cause the issue. Blow main check would cause the issue.
