Jetpro Unsilenced Vs Silenced!
Borley
Essex,UK
What would people recommend as this seems to be the easiest upgrade for power? It`s for the FGMT, i have heard that the silenced version has slightly less power than the unsilenced and the muffler rquires repacking. So i`m in 2 minds, if noise wasn`t a problem in my area i would deffintly go for the unsilenced. What sort of maintanence does the silenced one require?
Thanks
Guy
cyclops1970
Hamilton Ontario Canada
Thanks
Guy
Buy aSilenced one and if you choose to you can drill out the rivets and take out the wadding inside the chamber and then put the end cap on the pipe and run without a silencer .. and its your choice from there ..
Good luck !
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Good luck !
I agree go with the silenced. From all the people that have the silenced its a snap to replace the wadding (Heck Timmahh made his own at one time) and really its not a performance inhabiter that you would probably notice the end just allows the wadding to absorb some of the db's, noise, not to stop air flow.:)
