Kirkville1
Junior Member
- Reaction score
- 0
Got this on craigslist for a good deal...now I'd like to get a body and fix it up. Trouble is I'm new to these and can't figure out which redcat this is. Please helpView attachment 7269
Basically its the same both are built on the same chassis, both have 2 speed tranny except the thunder quake has reverse. Also the part are a little more hopped up on the thunder quake not by much but you can also convert the nitro quake to a thunder quake with no issues. Width wise the thunder quake sits about 1 1/4 inch lower to ground and is about bout 1 1/4 inch wider wheel base wise. Other than the reverse there is not much signigicant difference to noticeKirkville1 said:How do I tell the diff between each?
You should still be able to get them on tower hobbies and ebay has alot of parts, surprisingly alot of duratrax parts are interchangeable i have other duratrax trucks that i swapped out with my thunder quake and nitro quakeKirkville1 said:That's sweettime to tear into it now and clean it up..looks as if it's missing the servo arms to the brakes... Where is a good place to buy replacement parts ...seems like most are limited on parts for the quake
