Just bought this on craigslist ..trying to identify
It does not look like any current Redcat models. What scale is it? Looks like a 1/8. The Redcat bodies will still work.
That is either the Duratrax Nitro quake or the Duratrax Thunder Quake lol i've owned the both and you can easily customize both of them
Kirkville1 said:
How do I tell the diff between each?
Basically its the same both are built on the same chassis, both have 2 speed tranny except the thunder quake has reverse. Also the part are a little more hopped up on the thunder quake not by much but you can also convert the nitro quake to a thunder quake with no issues. Width wise the thunder quake sits about 1 1/4 inch lower to ground and is about bout 1 1/4 inch wider wheel base wise. Other than the reverse there is not much signigicant difference to notice
Unless you go all out with it like I did this one, you won't notice the difference. lol here my my fully modded thunderquake that I put up for sale
http://www.ebay.com/itm/111293257001?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1561.l2649
http://www.duratrax.com/faq/product-faq.html#q671
That's sweet ;) time to tear into it now and clean it up..looks as if it's missing the servo arms to the brakes... Where is a good place to buy replacement parts ...seems like most are limited on parts for the quake
You should still be able to get them on tower hobbies and ebay has alot of parts, surprisingly alot of duratrax parts are interchangeable i have other duratrax trucks that i swapped out with my thunder quake and nitro quake
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR11.TRC1.A0.H0.Xduratrax&_nkw=duratrax&_sacat=0&_from=R40
http://duratrax.com/
