Branson_Basher
I'm going to take the time to go through everything and try to make sure it's built properly.Identical to how my old one started out ? stayed like that for just a few weeks
+1.nice parts except the air filter...thats no good
Yeah, I got too looking at it and it only has metal mesh for filtering. There is no fabric or paper filtering element to it so I doubt it'll clean the air very well. I won't be using it.Cool build??......nice parts except the air filter...thats no good
Yeah me too, for like 5 minutes until it’s not flowing any air at all ?I bet it flows a lot of air though...
For onroad its ok..Yeah me too, for like 5 minutes until it’s not flowing any air at all ?
Yeah for sure, but what are you gonna do with a class one buggy on roadFor onroad its ok..
The gears and everything needs to wear in, plus with a greased wet up there will be some resistance till its worked up and the grease thins out a bit. I wouldnt worry too much.I'm ordering a proper air filter from DDM since I'm going to be running it in very sandy and dusty conditions
Wow. I mean, wow!
Turtle Racing makes some seriously nice stuff! The finish of the machined surface, the fit is unbelievable, very nice design. Super happy with the product and honestly, after assembling the transmission I'd have probably paid more than they're charging.
The bearings that came in my KM are not soo nice though...
I started spinning the bearings while I had them out of the stock transmission and they have a good amount of rolling resistance. After getting the TR transmission together (only a medium amount of grease) there is much more resistance to the spinning the assembly than I like. Like, I'm actually kinda concerned here.
Maybe the bearings will "free up" with some run time?
i had my gears/bearings explode in my tr case and amazingly it kept it all in side....only just....it deformed the lower bit of the case but nothing major?..When I dry assembled the transmission I looked at the backlash between the gears and found it to be perfect. The backlash being soo spot on was one of the things that impressed me soo much with the TR transmission. The accuracy of the machining is truly first rate.
There is no "running in" of the gears to be done here. All of the resistance is coming from the sluggish bearings. Well, a little is from the grease but not much. I'm careful not to over grease gears.
I'm hoping the bearings will loosen up with time but it's not ideal. I'm going to run it but when it's time for a rebuild I'll replace them with premium bearings.
long as there rubber sealed bearing then they b fine?.....imo....buying "top shelf " bearings is a waste of $€£....?...unless u race hardcore that is? then u may gain 0.06 a lap with pro bearings ??I'm really considering replacing the bearings with premium ones. The case is sealed so well I don't see the need for sealed bearings here and the drag is significant.
This is one place where I can see the value of nice expensive bearings. No doubt the engine will put more power to the wheels if the transmission was more free turning in there.
?...furr nuff? bin em then??It didn't work.
The bearings are as stiff as I am in the morning when I wish they were a bit more loose like my ex gets after a few drinks
staaahhhhpppp mike?...furr nuff? bin em then??
hmm..got her number??
