Sorry about that . I typing too fast . The issue is . When I start it . It takes power right away . I have to hold the brake to keep it from moving .Can you read what you wrote and kinda fix it? Me reading it your stating as soon as you start it the truck is stopping with the brakes. Next sentence reads as soon as it starts it stalls and then takes off on you as If it's still running.
Thank you so much . I will definitely do it . Thanks again .Ahh gotcha. Your idle is too high turn down the idle screw. Here's a pic, put the truck up so the wheels are off the ground, start it and slowly turn the idle down till the wheels stop spinning.
