hey trip you should go for the same set up as i run at the moment,it is the elcon set up and trust me when i ran it it is amazing in every department.
clutch pinion is a 19tooth with a 45 tooth spur gear.
layshaft is a 16tooth with 48 on the diff.
some set up...
if you can get these gears on yours trip it will be perfect.
You could drop to a 46/18, or go for the alloy rear hubs which will raise the rear top arm slightly, or go for alloy top arms which will prevent the flex and sprocket eating...lol
