ccpm raptor
- Thread starter
- #21
Have you done this mod? do you think it it necessary? thanksThere is a mod you can do to to it, if your really worried about it. You'll need 2 nipples and a small length of hose. Basically you install one nipple in the vent hole. Normally some epoxy or what not is helpful to make sure it stays in place. Grind down the inside of the nipple so it's flush with the plate. Second nipple goes in-between the carb and air filter. Doesn't really matter where so long as it's in front of the carb and after the filter. Attach hose in-between. You've just done 2 things. Made a pressure compensating carb (will limit diaphragm movement if the filter gets plugged up badly, keeping the engine from running pig rich) and filtered the diaphragm air. It's pretty std on all saws now a days. Works well. No extra fancy stuff needed.
