- Crafers South Australia
Im playing around with center diff and ......just wondering if the diff cup will work on the front and rear diff cases ? has anyone tried this?
Thanx for looking a?? although irp and pro am dff cup are sold to fit anywhere ? they don't stipulate only center or only front/rear???just compare the part #s in your assembly manual and see, spur gear and ring gear most time have different offsets and bolt spreads
I was looking at our 5b manual and it shows only one diff! Rear only ! ....Got to love the simple man car ! Lol
Did the dbxl come with an alloy center?Same for the dbxl/mtxl platform. All 3 diffs are the same.
you do know that I was yanking your chain, I was talking about 2wd hpi 5b.....Rear only! But still your manual should show breakdown with part#s and that will tell ya if you can mix up the group or notThanx for looking a?? although irp and pro am dff cup are sold to fit anywhere ? they don't stipulate only center or only front/rear???
Tlr did a plastic center and the other two plastic ?
Why only yanking his chain!????? I could use a good yank right now, feeling a little cramped up. ???? But I looked and the front diff cup is LOSB3201, center diff cup is TLR252010, and rear is LOSB3201. So front and rear are the same but the center is differentyou do know that I was yanking your chain, I was talking about 2wd hpi 5b.....Rear only! But still your manual should show breakdown with part#s and that will tell ya if you can mix up the group or not
One plastic one alloy??Why only yanking his chain!????? I could use a good yank right now, feeling a little cramped up. ???? But I looked and the front diff cup is LOSB3201, center diff cup is TLR252010, and rear is LOSB3201. So front and rear are the same but the center is different
