Let us know how it goes. You have any pix of it? Tell a lot from a pic.Thank you guys for the reply’s I do really want the 2.0 version but can’t afford to spend $1600 at this time. Came across this guy here locally and thought it look like a good deal.
I say you can get it for 600-700 if you know how to beat the price down with all this stuff... that's only if you are a professional lowballer like me thoConsider replacing all of the bearings
The engine could be tired, could roughly cost 600 to upgrade to a modern engine
The tires could be rough and dry rotted, the rims and foams will be ok but count on atleast 100 for new tires
The servos most likely won't survive 6 months of use again so that's roughly 100-150 a piece
May need a carb at 60 bucks with gaskets
Air filter foam is most likely wasted so that is another 50-100 depending on what you want to do there as an upgrade.
Tearing all the diffs apart as they need new fluid and gaskets/o rings
You get my point.
You couldn't even buy a junk rm 90 for peanuts last year... worst negotiator ever.I say you can get it for 600-700 if you know how to beat the price down with all this stuff... that's only if you are a professional lowballer like me tho
