Clearance issues or not, i don't mind, the Bartolone also melted the cage at 2 spots, so can't be really worse IMHO.
The servo are not "over" traveling as my end points are correctly set. And i fried one Savox barely after 10min of it being installed (it was hot outside, around 85-90) and it reached 148 degrees... and the electronics fried inside, had to get it replaced.
When i run the SAME DBXL in winter time, or in chilly conditions, i can run it for hours and hours without a single problem, with same servo and Bartolone Pipe.
I reached Bartolone to see what they could offer as a solution, and they never came back to me. So quite frankly, for me, it's a 230$ down the drain as i CAN'T sell the pipe because of this issue, and also because i CAN'T use it summer time.
And by the way, i swapped the servo with the sterring servo, and the problem remained at the throttle, the servo performed like it should on the steering, so the problem really is because of overheating issues, as i did check the temp of the servo casing, and the problem was only when the case of the servo reaches 140 degrees or more that it start glitching, over 145, it stops working.
If i can manage to keep the temp under 140, everything works fine... but when it's 90 outside, forget this, that area is always around 150 degrees...
The bartolone goes over the throttle servo by 1/2 to 3/4 of an inch, which is way too close. With the pipe reaching easily 250-270 degrees in hot temperature outside, the heat that radiates from the pipe, wrapped or not, will do the same thing.
Any pipe that goes that close to the pipe will suffer the same thing, this is not a new thing, many people had that overheating problem with certain pipes on the
Losi 5ive-T, now i get this on the DBXL and i am not the only one around here that had overheating issues related to the Bartolone pipe or similar that goes too close to the throttle servo.
I tried everything i could to help out lower the temp, found no other real solution then to turn to the VRC Pipe, which is designed to go as far as possible from the throttle servo, which i think, will resolve my overheating problem caused by the pipe going too close to the servo and radiates heat and transfer it to the servo, which results in loss of pleasure because i have to wait for the servo to cool down to start playing again.
Just sharing my experience of the Bartolone pipe... Beside that overheating problem the pipe performs very well, plenty of power all across the band, low, mid or high RPM, have nothing to say about that... but the heat is a REAL problem for me.
