Was just o DDM looking at front center drive ?? and I was always under the impression that 5b and 5t v1 bla bla fc drive was the same same? but phatdad has one for each?
. @evssv or @crucialRC get out ur little ? rulers?
?Was just o DDM looking at front center drive ?? and I was always under the impression that 5b and 5t v1 bla bla fc drive was the same same? but phatdad has one for each?. @evssv or @crucialRC get out ur little ? rulers?
Yes the one going from the center to the rear ?? but the front drive...... is it longer??5ive-T chassis is longer so drives should be longer. I'll measure in a few.
I've gotta love ya Doug, you know how much of a PITA it is to take the body off the T? Both are about 4.75" trom center of the front pin to the start of the universal. So length is the same, but the T is 7.15mm thick and the B is 5.9mm.
Yeah, not sure. T prob weighs a good amt more than the B.Luv y bro???........ wonder why they
Made it thiner? a weight thing?
yyid?Yeah, not sure. T prob weighs a good amt more than the B.
Wont respond either.They went under im assuming ?Wonder when/if Team Phatdad will be making more losi/hpi drive parts??
View attachment 57495View attachment 57496
Been like that for a long time?
YEEESSSS!!!!?NOOOOOO!!!!☹
Is it notably thinner the front and rear??when I bought my phatdad drive shaft ddm had the one for the 55ive t out of stock but he said the 5ive b front drive shaft works. call and check?![]()
I doubt it will be an issue unless you go to a 65cc+ big boreI think I would get the T one cause its thicker. Is yours bent or broke in the B?
I’ll have to checkYes that's what I thought ? don't understand why they "PD" would make one for each?![]()
?been there, done that?I doubt it will be an issue unless you go to a 65cc+ big bore
