LSN lean side or engine dies (update, is it dead?)
Update: see post #18
Finally my brand new KSRC001 arrived and after having charged the battery it was time to fuel the thing up and fire. But there the adventure stopped, no sign of life (following the well known start procedure).
The first step was closing the needles and setting it bach to 'factory', meaning 1.5 for HSN and 1.25 for LSN. Again no success. I took out the spark plug and it was wet, so fuel entered the engine, but that was it.
My final attempt in getting the enginge running was fully closing the needles (clockwise turn, and yes I know it very very lean). To my surprise after 3 pulls with the choke, it made some noise. I set the choke off, and after 2 pulls it fired
but it died fast. I repeated the start procedure and immediately opened the needles and the engine did his job.
Currently my settings are HSN: 1.5 turns and LSN 0.6 turns. I have got a question regarding the LSN, it on the very low side compared to a factory setting. Do I have running it too lean?
I would like to make one side note: I can richen the LSN a bit more, but then the engine stalls. Only if I put the idle screw more in, I'm able to richen the LSN a bit, up to ± 0.8 turns out, but the idle is screwed fully in.
