Maverick Blackout belt drive system
johnboy
Active Member
Wakefield
Hi does anyone know where I can buy the belt drive system from for my maverick blackout v2 any help would be much appreciated
Hi yes the problem I’ve got is the exhaust side is a lot bigger then the exhaust side too big to hose clamp it and doesn’t work if you put the smaller rubber hose inside the bigger one
Guys is your manifold the same size as the other part of your cpi exhaust the end where you connect them both
Do you mean the header is a different diameter to the pipe?
If so you may have to contact the seller.
You may have the wrong header.
Are belt drives still available somewhere? Stripped metal gears from my MT and was looking at replacing the gears with belt drive. However, seems they are selling "out-of-stock" everywhere :(
No the carbon fighter has 10mm shafts and Redcat are 8mm.
You might have to contact the seller about the Redcat one.
I got mine from him.
He only speaks German so you'll need to use google translate.
when you get it. dose it come just with the pullys and gears or dose it come with the gear plate to?
As an update, I never got any answer from Stern CNC, not even into email written in German. Ended up replacing the metal gears with new ones (35 euros shipped from China).
