MGM / T.P. Power motor combo ploblem
Timritchieblue
Having a problem with this combo. After install, truck would only go 1/3 throttle before shutting down. So I tryed to replicate problem on bench.
Any Ideas?
I got new parameter settings from Martin, everything seems fine now. Logs look good. Had to make some adjustments with the T.P. POWER motor
Model 5680, 800kv
These are the settings that smoothed everything out
p.52 10*
p.51 PWM 8khz
p.16 to 1.5 sec
p.22 80%
p.21 freewheel (yes)
Not very long really, about 10-12mins. I run turnigy 5000mAh HD 6s packs, should spend more money on better packs. But their high $235 each.
