ccpm raptor
The vertigo trans plate has one on it mateI have a 2.0 with a modified diff tower and I may do the same. How'd you drill and tap. Im curious because my vekts could really use this as the rcr disc likes to flap around and bund the disc
Did you ditch the brake shoe springs for disc clearance? I tried the RCR brakes on my 2.0 with the modified tower and the springs got in the way. I went back to stock.Rcr Brakes were binding/catching when the diff was tipped forward or back. I added their 1.0 brake guides to their 2.0 diff tower.
No the disk was to large to allow to keep the springs on. So I ended up doing the spring mod on the brake linkage to keep the lever from making contact on the brake pad.Did you ditch the brake shoe springs for disc clearance? I tried the RCR brakes on my 2.0 with the modified tower and the springs got in the way. I went back to stock.
I looked at those after I had the RCR. I like the idea of greasing the cups. I bought a can of Blaster silicone spray I thought of using on the driveshafts and dog bone. Not sure if it is a good idea or not though.I run modified rc booted discs without springs..no issues you'll be fine
Details on the spring mod? Looks like maybe just some springs from a ball point pen, some rubber grommets and a sleeve on the end of the rods?No the disk was to large to allow to keep the springs on. So I ended up doing the spring mod on the brake linkage to keep the lever from making contact on the brake pad.
Agreed. But in my head I thinking it keeps pressure levers all the time. In turn keeping them from make any contact to the brake padsIf your brakes are set up right there's no need for springs in the rod to keep them from making contact when your on throttle.
Yes. Since there is no room for springs between the pads. I though I would keep the lever making connect at any time other than braking.Details on the spring mod? Looks like maybe just some springs from a ball point pen, some rubber grommets and a sleeve on the end of the rods?
